98 blazer sounds like it has big mud tires on it at 60 plus mph
Old 08-02-2013, 04:26 PM
gmaltese's Avatar
gmaltese is an unknown quantity at this point
Default 98 blazer sounds like it has big mud tires on it at 60 plus mph
could the front wheel bearing bo going bad, rear wheel drive
Old 08-02-2013, 04:30 PM
chris015's Avatar
chris015 has a spectacular aura aboutchris015 has a spectacular aura aboutchris015 has a spectacular aura about
yessir. that or you need to change oil in the rear, or bearings in rears going out.
Old 08-02-2013, 04:43 PM
rexazz2's Avatar
if you can sweep left to right at that speed so the vehicle weight transfers
The noise will usually subside when you take the weight away
Old 08-29-2013, 06:25 PM
gmaltese's Avatar
Default up date to noise
drivers rear axle bearing bad, bearing cut axle. had both side fixed, new bearings new axles. drives like new
lecktrix
04-02-2012 10:48 PM
coltkid1988
02-01-2010 11:44 AM
rraasch04
08-08-2009 09:20 AM
SuperBlazer
14
03-03-2009 07:46 PM
prozach1988
02-23-2008 07:39 AM
Quick Reply: 98 blazer sounds like it has big mud tires on it at 60 plus mph
