98 blazer start and runs a few seconds and dies
Old Jan 16, 2007 | 04:47 PM
adamsrg's Avatar
adamsrg is an unknown quantity at this point
Default 98 blazer start and runs a few seconds and dies
I have a 98 blazer 4.3l and it will start and run for a few second and then die. I have checked the fuel pressure and i am getting 63 psi and i have checked the relays and they are good. I put about 5 gal of gas because the gauge read E and the gauge still did not move if and body can help please do before my wife make me sell it.
Old Jan 17, 2007 | 03:19 AM
MNHawk's Avatar
MNHawk is an unknown quantity at this point
Default RE: 98 blazer start and runs a few seconds and dies
add more gas
Its a known issue posted here before about being under 1/4 tank and having run issues.
Try that first. If that does not help then have to dig deeper into it.
Old Jan 17, 2007 | 08:50 AM
paulierizzo's Avatar
paulierizzo is an unknown quantity at this point
is security light on ?
Old Jan 17, 2007 | 01:47 PM
filstoy's Avatar
filstoy is an unknown quantity at this point
I know you said you already checked it, but I would try swapping out the relay in the electrical center under the hood. There are a couple under there that are the same relay that you can swap it with . What you are descibing is exactly the same thing my 99 did a couple of months ago. Start fine, run for a couple of seconds and die. Would do it every time. I was at a retirement party so I was stuck but I lucked out and got a call from my brother in law who knew what it was. Swapped it with a headlight relay or something (don't remember exactly but it was the same relay) and it ran like a charm.
Old Jan 17, 2007 | 07:06 PM
i have a 99 with same problem, got it running today .i dont know if your interior lights are off also, and under hood light, rear hatch button? if they are look tbc fuse under hood by relays look good mine was blown and didnt really look like it. its 10amp.
Old Jan 18, 2007 | 06:29 PM
adamsrg's Avatar
i put ten gallon of gas in it and it does the same thing. I replaced all the relay in it and still nothing.
i do not see a securty light where is it located at.
Old Jan 18, 2007 | 08:22 PM
filstoy's Avatar
It's right on the dash in plain sight. If it was on you would probably have noticed it already. Sure sounds like the computer shutting you down somehow. I'll look through the service manual and see if there is anything related to the fuel sender that could shut you down since you say it's showing empty. This stuff is great when it's working but what a headache when it's not.
bluhming
Jul 9, 2015 01:01 AM
SteveBessert
Aug 7, 2014 04:29 AM
ek72
Jul 14, 2011 11:09 PM
reddheadnla
Apr 23, 2011 11:08 AM
