98 gmc jimmy/blazer NEED HELP wit trans problem ASAP
sorry cartunez. i just got in (midnight), and see i missed a call from him regarding your trans problem. he asked me which way the trans was locking up? these trans are notorious for the kickdown failing on the 3 to 2 shift (like you stated above). but the code shows that it's a 2 to 3 shift solenoid. he said that there is 5 solenoids and a pressure switch in there, and would like to know which way the lock-up is occuring, and if you noticed any damage to the wires inside?
i'm gonna call him in the morning, and see if there was anything else he didn't tell me on his mssg from tonight.
i'll post as soon as i get off the phone with him, not sure what State you're in (time zone), and not sure if you can see this during the day, but i'll post ASAP regardless. it's currently 12:08am here.
ok cartunez2004, here's what my guy had to say. check your wiring for a short. this code won't be thrown for a bad solenoid, plus you said you replaced it already (he hopes the short hasn't fried your new solenoid too). start checking the pan harness, and work your way back up through the truck's wiring harness from there. he suggested finding a schematic for the wiring to help trace the correct wires. you'll need to check the harness right back to the bulkhead (it's gonna be a bitch around the trans/engine so be patient). he said to be on the lookout for areas that show signs of rubbing.
good luck.
good luck.
good luck.
good luck.
ok. but have you checked the rest of the wiring harness yet?
i kinda trust my guy-he's never steered me wrong in the 14 years i've known him. and i think he knows his stuff pretty well, he's owned a Mr. Transmission location for 20 years now.
CompTechMike
02-17-2012 09:39 PM
cartunez2004
10-23-2009 04:21 PM
