98 S10 Blazer dies when you step on the gas
Old Jan 18, 2007 | 04:47 PM
jginnc's Avatar
jginnc is an unknown quantity at this point
Default 98 S10 Blazer dies when you step on the gas
I have a 98 S10 Blazer, that starts fine, go into reverse to back out of the driveway fine. Put it in drive and step on the gas it dies. put it park, turn key off and then back on, starts up a little rough, but runs. Put it in drive and go. runs fine. Can stop and start it again with no issues. I can hear the fuel pump come on before I turn the key, and it runs for a bit after I turn the key off. This happened once about a month ago, now it is happening regularly. I have owned the truck since new and it has 160,000 miles on it. I have not replaced the fuel pump or the fuel filter. Any ideas will be appreciated!
Old Jan 18, 2007 | 07:32 PM
nofear17bmx's Avatar
nofear17bmx is an unknown quantity at this point
Default RE: 98 S10 Blazer dies when you step on the gas
Pretty sure the fuel pump is suppose to come on for just a little bit when you turn the key to acc.
Old Jan 18, 2007 | 07:35 PM
MNHawk's Avatar
MNHawk is an unknown quantity at this point
160,000 miles and have not replaced the fuel filter yet. Man that thing ought to be full of junk by now.
I would start there first. Might also be why you here the pump whining after you do start it. Forcing it to stay up to the PSI needed to keep running.
NCRD1331
May 9, 2013 08:31 AM
chevyblazer9588
Nov 20, 2012 10:40 PM
poertsch
May 3, 2012 06:12 PM
rudd21
Nov 12, 2011 03:49 PM
toaks
Detailing
Aug 26, 2008 11:44 AM
