99 4.3 slight intermediate skip/miss
Old Apr 28, 2015 | 10:52 PM
gatrucker99's Avatar
gatrucker99 is on a distinguished road
Default 99 4.3 slight intermediate skip/miss
my 99 4.3 was running perfect no skipping missing no nothing no cel and on Friday it blew a lower intake manifold gasket, I tore it apart and replace the lower intake manifold gasket put it all back together and it runs perfect again other than a small skip/ miss but it doesn't do it all the time any thoughts on that?
new plugs right after fixing, recent cap,rotor,wires,iac,tps
Old Apr 29, 2015 | 01:05 AM
newguy's Avatar
My truck was doing this. Look under the hood at night ,check the spark plug wire for arcing. You,ll see a blue spark and may even hear it
Old Apr 29, 2015 | 06:22 AM
perumotors1369's Avatar
perumotors1369 is on a distinguished road
If it didn't have it before, it 'most likely' is something you did/touched. Goo back over all you did....hoses tight, not cracked (a carb cleaner may help with this)..all electrical is plugged in properly (ie plug wires seated to cap tightly)..good luck...Jerry
Old Apr 29, 2015 | 07:33 AM
newguy's Avatar
Yes, agreed
Old Apr 29, 2015 | 08:17 AM
alright. will check. and i cleaned throttlebody really good whennit was off already.
thanks i will post what i find
Old May 2, 2015 | 11:24 PM
i found a bad spark plug wire havent. replaced it yet. but pretty sure thats causing the problem
Old May 3, 2015 | 04:04 AM
newguy's Avatar
I would bet thats it. Let us know
Old May 5, 2015 | 04:39 PM
Default P1345
captain hook. i never have had a p1345 code until i had to change lower manifold gaskets and put the distributor back in how do i fix it
thanks
Old May 5, 2015 | 05:36 PM
With the ignition off: Using a ratchet and socket on the crankshaft center bolt, manually rotate the crankshaft ONLY clockwise until the timing marks are aligned like this:
AND the rotor is within a few degrees of this:
Remove the distributor and install it so the rotor points to the #6, (or very close) on the distributor housing when the distributor is fully seated against the intake manifold. DO NOT rotate the crankshaft while the distributor is removed.
Old May 6, 2015 | 06:36 PM
i did tdc and rotor is close to pointing to the 6
i would post picture but i cant get it to upload for some reason
