99 4.3 slight intermediate skip/miss
Old May 6, 2015 | 07:05 PM
If the P1345 is being set, the distributor is not installed correctly, (that's what the DTC means). The rotor needs to point closer to the 6 than it is. It's probably only off by one tooth. The crankshaft MUST be lined up as indicated in the post above. Only turn the crankshaft clockwise. If there is any slack in the timing chain, turning the crank counter clockwise, (even a little bit) will not position the camshaft correctly.
Old May 6, 2015 | 09:03 PM
gatrucker99's Avatar
gatrucker99 is on a distinguished road
here is where it sits at tdc
Attached Thumbnails 99 4.3 slight intermediate skip/miss-blazer1.jpg
Old May 7, 2015 | 03:38 PM
The flat part of the distributor housing needs to be facing the front of the engine, and it should be parallel with the rear of the engine. If that's the case, the distributor needs to be removed, and the rotor needs to be turned clockwise one tooth, and reinstalled.
Old May 12, 2015 | 02:04 PM
got it fixed captain hook. thanks
ussexplorer
Sep 27, 2013 03:38 PM
jasonblinn
Jan 26, 2011 10:23 AM
RobMacLin
Oct 18, 2009 09:23 AM
LittleDan911
Feb 2, 2009 01:27 PM
