99 blazer blowing hot air with a/c on
Old Jun 1, 2014 | 02:07 PM
putz1699's Avatar
putz1699 is on a distinguished road
Default 99 blazer blowing hot air with a/c on
when it started warming up this year I did a full service on my a/c system and everything now works as far as compressor and system weight and charge levels. its still blowing hot I do not think the heater valve is closing and haven't been able to find it. anyone have any suggestions?
Old Jun 2, 2014 | 06:30 AM
dobyken's Avatar
dobyken is on a distinguished road
There is no heater valve...hot water constantly flows through the heater core. What comes out of the vents is determined by the "Blend Door" which is located under the glove box. A common problem is that a gear strips and gets stuck. There are many posts here on the problem and how to fix it.
Old Jun 10, 2014 | 05:27 PM
JUNKYARDDOG2001's Avatar
JUNKYARDDOG2001 is on a distinguished road
hello i have same problem how hard is it to change blend door
Old Jun 10, 2014 | 05:52 PM
When the A/C is on, if the accumulator is cold, and the lower line at the evaporator is warm/hot, chances are there's a problem with the temperature blend door actuator.
IF that's the problem, (temperature blend door actuator) the glove box needs to be removed to gain access to the actuator, (item #3 in the image below). It's a tight fit getting your hand and tools in there, but it CAN be done without removing the instrument panel.
The actuator is available at most auto parts stores. You'll need to tell them if you have manual HVAC, or Automatic Climate Control, (2 different part numbers).
Attached Thumbnails 99 blazer blowing hot air with a/c on-blenddooractuator_zps79363c8a.png
Old Jun 11, 2014 | 06:13 PM
thanks ill try it its realy tight
jchowell1
Dec 13, 2012 05:53 PM
Mandrwj
Apr 10, 2011 07:32 PM
ravenhurst
15
Apr 26, 2009 07:53 AM
bl_zer
Nov 23, 2008 11:14 PM
ItradeNDX
Feb 3, 2006 05:21 PM
