99 blazer fuel woes
Old Jan 10, 2016 | 04:16 PM
  #21
Fat Snook's Avatar
Fat Snook is on a distinguished road
Ok I did that and now I have my 12v key on for 2 seconds. Then 12v key off for 2 seconds. Had power with the prime terminal too. I am at a loss here. I have power but no pump activation. Starting to think I have a bad new pump. Guess I need to pull the pump and check the internal wiring. I think the no voltage was caused by my meter probes being a bit too big so I cut some y connectors and inserted those into the pump connector. Now I have voltage through the key. I'm sonconfused.
Old Jan 10, 2016 | 06:33 PM
  #22
The prime terminal showed battery voltage for 2 seconds with initial key on? But still no noise from the pump, and no fuel pressure at the service port?
Old Jan 10, 2016 | 06:38 PM
  #23
Fat Snook's Avatar
No I checked the prime terminal first. Then rechecked with the key. Power both ways.
Old Jan 10, 2016 | 06:45 PM
  #24
It's either losing power somewhere from the prime terminal to the pump, or losing ground to the pump, or a bad pump. Next step is check power and ground at the pump module connector. Apply battery voltage to the pump prime terminal and check the grey wire in the pump module connector, it must show battery voltage. The ground wire must show less than 5 ohms resistance to ground. When I replace pumps, I install a 10ga wire, soldered on, from the connector to a good chassis ground. What brand pump did you install? How old is the pump? Is there a warranty on it?
Old Jan 13, 2016 | 11:31 PM
  #25
Fat Snook's Avatar
Ok so I decided to add the ground at the pump. Wish I did that in the first place. Thank you for all of your help.
Old Jan 14, 2016 | 10:21 AM
  #26
Glad you found it. Thanks for posting back.
Old Apr 17, 2016 | 04:05 PM
  #27
Fat Snook's Avatar
Well I'm dead in the water again... this time I have power but no pumping of gas... looks like a new pump in my future. Could I be missing something?
Old Apr 18, 2016 | 07:30 PM
  #28
Fat Snook's Avatar
It's the pump. BUY OEM!!!!!
Old Apr 18, 2016 | 08:50 PM
  #29
odat's Avatar
I have Sad news for you - The last two pumps I installed for people in my shop, one AC DElco and one Delphi and I have bought other parts of AC Delco and Delphi all were stamped MADE IN CHINA - and no I don't do Ebay - all from Carquest, Napa and Orilleys
Steinkebunch
Dec 25, 2015 07:27 PM
Rubbed Radish
Dec 28, 2011 03:22 PM
zpopples
Feb 1, 2011 10:02 AM
theonetruetom
Jan 30, 2011 09:06 PM
robert8868
Aug 18, 2006 12:22 PM
