99 blazer hard starting when warm
Old Sep 26, 2013 | 11:15 AM
cobra49327's Avatar
cobra49327 is on a distinguished road
Default 99 blazer hard starting when warm
Hey there my blazer has 157k on it and it starts fine when its not ran overnight or 8hrs after it sits but when you start it after the first time it takes 30 seconds or longer to restart you can turn the key back and forth as many times as you want and it don't help it has a new fuel pump can any one help me?
Old Oct 10, 2013 | 10:27 AM
rexmburns's Avatar
Super Moderator
Moved To: 2nd Gen S-series (1995-2005) Tech
Old Oct 10, 2013 | 10:47 AM
WalkGood's Avatar
WalkGood is on a distinguished road
Need more info, like does the starter engage?, just click?, nothing?? Does the engine turn? Any sputter?
Old Oct 11, 2013 | 04:53 AM
cobra49327's Avatar
The starter rolls fine it starts and dies instantly then it rolls over and over and over for 30 seconds to a minute before it fires up but runs fine after it starts only code is a evap code for small leak
Old Oct 11, 2013 | 04:57 AM
cobra49327's Avatar
I'm leaning towards the fuel pressure regulator or injector spider but not sure. The fuel pump comes on as soon as you turn the key on also
Old Oct 11, 2013 | 06:51 AM
rexmburns's Avatar
Super Moderator
Do a fuel pressure/leak down test on it and post your results.
Old Oct 13, 2013 | 09:25 AM
cobra49327's Avatar
Fuel pressure key on motor off 62lbs running 55lbs any ideas not had a tps code iat code and iat is reading pretty high temp it was 76 outside and iat was 135 and there was a p0300 code and o2 sensor codes and if you take the iat out and blow on it for a lil bit the blazer would start easier
Old Oct 13, 2013 | 04:30 PM
burned's Avatar
burned is on a distinguished road
I am guessing you have a scanner?
Let the vehicle sit overnight and then without starting it check what the IAT and ECT are reading compared to the outside temperature.
sparky672
Nov 6, 2011 08:56 PM
cgrett
Nov 15, 2010 09:08 PM
sidewheeler
Jun 17, 2009 10:03 PM
spunbearing
Sep 26, 2007 05:01 PM
Inferno
Oct 22, 2006 08:56 PM
