99' Blazer leans to the right
go bend one of your rims so its gotta gangster limp to go with that lean, lol.. jk
It is definitely your torsion bar I am an alignment tech and i see this more then you could imagine. just zip the bolt in and magic will happen. If the bolt is maxed that means that that torsion bar is shot. A solution is measure on the frame behind the front tires on both sides then go to the opposite torsion bar and lower it a little. Now the only down side to adjusting height with a torsion bar is it will mess up your camber, and it will also change your frame angle. So don't go to dramatic. You might end up with a crooked steering wheel. If you have to go anymore then an inch to an inch 1/2 then i whould suggest bringing it to an alignment tech so they can fix the thrust angle after they level it. Let me know if you want to know anything else
wait wait wait...does that mean some alignment shops might be adjusting my torsion bar/other torsion bars?? This might explain why so many owners try to lift to find their bolts all the way in!!
tyson0016
10-30-2007 04:41 PM
redpeppers
04-07-2007 04:55 AM
