99 Blazer - Quad Headlight Mod & DRL delete
Old Jul 20, 2015 | 11:05 AM
mickey_bigdaddy's Avatar
mickey_bigdaddy is on a distinguished road
Default 99 Blazer - Quad Headlight Mod & DRL delete
Thought I'd ask the question about my efforts to convert to quad headlights and turn off my DRLs. My DRLs are my high beams. I don't want to disable my auto head lights by adding a resistor. I'd like to keep that function.
So, I added the ground wire to the to the yellow wire on the drivers side harness for the quad headlight setup. It worked great, I have quad headlights when I switch to high beams. Then, I bent the relay terminal #86 so that it would not connect to disable the DRLs.
Results: I have the quad headlights no problem. But, now my DRLs are my low beam headlights. Haven't seen this result in any of the posts I read.
Any way to get the the DRLs to completely shut off?
Old Jul 20, 2015 | 11:25 AM
Grounding the wire behind the driver side headlight will result in the low beams being on all of the time. I thought I had noted this in the thread I had discussing this mod when I had done it many years ago on my '00 Bravada.
If it helps, attached below is the electrical schematic for your 1999:
You will need to do a wholesale rewire of the headlight system to get around this. I thought I had worked it out way back when, but I could not find a marked up schematic with the necessary changes. I wish I had the time to work through it again, but I do not.
Old Jul 21, 2015 | 07:58 AM
Tajohns34's Avatar
You could always use a relay to use the high beams to trigger the low beams.
cr8390
107
Jul 17, 2018 10:58 PM
NVANZEE
May 6, 2010 01:57 PM
blazedandconfused95
Oct 22, 2009 12:26 PM
NVANZEE
Dec 22, 2008 06:18 AM
swartlkk
19
Sep 3, 2008 03:23 PM
