99 Blazer Turns Over But Does Not Start (any ideas?)
Old Dec 17, 2013 | 11:18 PM
CbBlazer22's Avatar
CbBlazer22 is on a distinguished road
Exclamation 99 Blazer Turns Over But Does Not Start (any ideas?)
I have a 99 Blazer 4 door 4wd and I replaced the blower motor a few days
ago, my blower stopped working again and so I checked the blower resistor.
The blower resistor was bad so I replaced that and now it blows air but it will
not start, I do not hear the fuel pump when I turn the key on.
any ideas?
Old Dec 18, 2013 | 05:22 AM
LannyL81's Avatar
Check the basic stuff first: fuses, both places, battery terminals and connections.
Do you have a voltmeter? If so, you can check the fuel pump test terminal for voltage with the key on; report your findings and then we can go from there.
Old Dec 18, 2013 | 02:05 PM
CbBlazer22's Avatar
I checked the fuses and switched the fuel pump relay with the fog light relay and still does not want to start, could it possibly be the fuel pump?
Old Dec 18, 2013 | 02:41 PM
rexmburns's Avatar
Super Moderator
Do a pressure and leak down test and that will be the quickest way to rule out or confirm the pump.
Old Dec 30, 2013 | 01:26 PM
sh8veds10's Avatar
sh8veds10 is on a distinguished road
if not the fuel pump, try the distributor or rotor...
Old Dec 31, 2013 | 09:21 AM
01xtreme_chevy's Avatar
01xtreme_chevy is on a distinguished road
If it is turning over like it should then your either getting no fuel or no spark. To check the spark plug simply pull it out and set the tip or threads on something metal and have someone turn it over, if it sparks you obviously got fire. To check the fuel pump turn the ignition on (don't crank) and you should hear a whinning sound coming fuel tank. If you don't then take some gas in a small cup and pour down your throttle body and try to crank it...if it cranks=bad fuel pump.
When's the last time you changed the fuel filter?
Old Feb 20, 2014 | 10:46 AM
Wild_Thing XI's Avatar
Wild_Thing XI is on a distinguished road
I have the same problem, it cranks but doesnt start, it happened a few times in the past several months but usually started and acted normal the next day for weeks/months. Now it wont start at all, I thought it was the ICM, I swapped it out from my moms blazer, hers started with my ICM in it, and mine still doesnt start. I'm guessing its the coil, rotor, or the distributor itself. The fuel pump and filter was replaced last year when my Dad owned it. Any ideas? I have a new cap, rotor, wires, and plugs for it but I dont want to do all that work and still not have it run (or start for that matter). Oh and a month or two ago I replaced just the cap thinking that was the problem, it worked for a few weeks as said before but it still has that problem. Any suggestions would be appreciated, thanks!
Old Feb 20, 2014 | 07:33 PM
vegie_2's Avatar
vegie_2 is on a distinguished road
Put a AC Delco cap and rotor on it. I had intermittent crank no start replaced fuel pressure regulator still had same problem, replaced fuel pump same problem, replaced spider with Delphi MFI same problem but it did run much better when it did start but I took off old NON AC Delco cap it had lots of corrosion but was only on there 2 years. Ive read on here about using only AC Delco and also the techs I know say that has fixed more intermittent no starts and swear by them just like Capt Hook and Swarrt. By the way these loan a tool fuel pressure testers at parts stores are pure crap they leak down or show the wrong readings so don't depend on them!!!
Old Feb 20, 2014 | 09:16 PM
rockp2's Avatar
Just because the fuel pump was replaced does not mean it isn't the problem. You should start with a fuel leakdown test to rule out the fuel pump. What brand fuel pump did you put in? If you look around the forum you will see that many times the problem was a fuel pump that had been replaced with an off brand. It seems to happen over and over. You have to use either Delco or Delphi fuel pumps. But still, do the leakdown test first.
Old Mar 4, 2014 | 02:05 AM
Thanks, I know its not a Delco, my father goes for the cheapest price, even tho I tell him all the time when it comes to vehicles, you should always buy what they need and not off brand things. I will do that leakdown test when it warms up a little. Its been around zero with 15 to 20 below windchills the last couple weeks.
1998mom
Jul 30, 2013 12:03 AM
Ksweat1241
Dec 22, 2012 04:37 PM
javaholic
Mar 1, 2011 07:33 PM
steve1969
Feb 26, 2011 09:39 PM
nolan
Aug 22, 2008 06:39 PM
