99 blazer wont start
Old Oct 17, 2011 | 04:44 PM
setkaos's Avatar
setkaos is on a distinguished road
Default 99 blazer wont start
my blazer was running just fine.........
1. ran out of gas
2. put gas from old gas can in friends yard in
3. ran for about 5 miles then died, wouldnt start
4. added more gas from new can with fresh gas (approx. 7 gallons)
5. added fuel injector cleaner as well as additive to remove water
6. still will not start, engine turns over
7. have tapped gas tank where fuel pump is while trying to start, no start
8. fuel pump makes noise when ignition on
9. disconnected fuel line from output end of fuel filter and gas comes out when ignition on
10. any suggestions? seems like something electrical, but not sure why caused by my chain of events.
please, i need my blazer....
Old Oct 17, 2011 | 08:25 PM
Mike98Blazer's Avatar
Bad gas? I'd start by draining everything in the tank since you don't know WHAT was in that can in the front yard (could have water and gunk in it). Change fuel filter. Put FRESH gas in.....then go from there.
When in doubt recheck the last thing you touched. In this case you put in gas from a can in the yard, i'd say that's probably your problem.
Old Oct 18, 2011 | 01:43 AM
setkaos's Avatar
what would be the best method for draining the gas? hopefully not involving dropping the tank
Old Oct 18, 2011 | 06:31 AM
Either dropping the tank, or if you're feeling froggy unhooking the fuel filter and powering the fuel pump and pumping it out into a can/jug and praying you don't clog up the sock on the end of the filter and have to drop the tank anyway.
dj00140
May 20, 2013 06:37 PM
JimmyBlaze541
May 2, 2013 10:00 AM
bobby099
15
Nov 7, 2012 07:29 PM
FreeTime
Sep 8, 2012 01:38 AM
jetsmy
Aug 1, 2008 10:10 PM
