99 Bravada AWD disable
Old Jan 23, 2016 | 06:24 PM
sky_blazer's Avatar
sky_blazer is on a distinguished road
Default 99 Bravada AWD disable
is there a way to disable the Smarttrack AWD system on a 1999? its just for a short period of time for one i wanna see if my gas mileage improves, but i also have a feeling its engaged all the time. i know its only supposed to engage AWD when the TCCM detects rear wheel slippage, but does that mean its RWD the rest of the time or is there a power split between the front and back? it just feels like 4WD even on hot summer day when its not even needed
Old Jan 23, 2016 | 06:46 PM
Yes it can be disabled, but it's not a "quick a minute" job. Removing the front driveshaft and disconnecting the encoder motor is the easy part. Both front half shafts will need to be removed as well. That's where the work and time come into play. The outer CV shaft holds the wheel bearings together, so you'll need to acquire two half shafts from a bone yard, disassemble them, and insert the outer ends into your wheel bearings, and torque the axle nuts.
Old Jan 24, 2016 | 04:17 AM
sky_blazer's Avatar
ya more work then i thought..is there a way i can see if the AWD is engaged even when its not supposed to be? how can i tell
edit: i just found some gas in my charcoal box, could this contribute to my bad gas mileage? what causes this besides topping off my tank? i do fill full almost everytime but i only get about 130-150 miles out of a full tank so i know im getting crummy mileage. according to my onboard computer im getting 14.5 MPG which is BS
Jonathan J. Janacek
Sep 4, 2012 05:45 PM
pettyfog
Aug 30, 2011 10:19 AM
rednekk
Dec 22, 2010 10:00 AM
82 Iron Duke
18
Nov 17, 2009 09:36 AM
rednekk
Apr 17, 2008 09:09 PM
