'99 Digital odometer issues
Old Mar 19, 2006 | 10:25 PM
Jeff_Cullen's Avatar
Jeff_Cullen is an unknown quantity at this point
Default '99 Digital odometer issues
I'm having a problem with the digital odometer/gear display on my '99 Blazer.
The display shows up fine when the ignition is in the accessory position, but disappers once I turn it to "on". Thus, I can't see the digital odometer display or what gear I'm in whenever the engine is running.
It continues to rack up miles (unfortunately!) so it's probably some kind of electrical issue in that the display isn't getting power when the ignition is on...
Anyone seen this before? Fuses/other stuff I can check?
Thanks very much!
--jeff
Old Mar 20, 2006 | 01:17 PM
Hanr3's Avatar
Default RE: '99 Digital odometer issues
Could be your ignition switch, and you did check your fuses right?
Old Mar 21, 2006 | 07:55 PM
Turns out it was the cruise control fuse... (!!!) The gas guage was stuck at half tank as well, and upon replacing the fuse went well below E! Yipes!
Old Mar 21, 2006 | 08:52 PM
Glad you got it figured out!
MikeMSU
Jan 4, 2015 04:05 PM
TheRemedy
Sep 15, 2013 09:53 PM
Blaussie
Jul 11, 2013 08:08 AM
shibbershabber
Feb 22, 2010 10:07 PM
Bl4z3r
Feb 10, 2009 08:39 PM
