99 Jimmy Wont start
Yes, that is correct, however, the timing mark on the dampener will line up with the index mark on the timing cover when #1 piston is at TDC of the compression stroke, AND TDC of the exhaust stroke. If the distributor is installed incorrectly, you'll end up with the symptoms that you have, (same end result as installing the rotor 180 degrees off). I didn't see any mention of the distributor being removed must have been the previous owner. If you need direction in phasing the distributor correctly, the easy way, let me know.
Check the rotor first. If that's installed correctly, then it sounds like the distributor is out of phase.
The engine will still start and run without doing the crankshaft position sensor relearn. However, ignition timing and injector timing will not be correct. They'll be "in the ball park" though.
Remove the distributor cap so you can see the rotor. Using a socket and ratchet on the crankshaft dampener bolt, rotate the crankshaft clockwise until it is positioned like this:
AND the distributor rotor is positioned like this, (or very close):
Next, carefully rotate the crankshaft one revolution clockwise until the crank lines up like the first image. DO NOT rotate the crankshaft counterclockwise. The rotor should now be pointing 180 degrees opposite of the "6". Remove the distributor and reinstall it so the rotor points to the "6".
[QUOTE=Captain Hook;659966]Check it! [URL]https://blazerforum.com/forum/2nd-gen-s-series-1995-2005-tech-41/how-check-regulated-fuel-pressure-pump-max-output-leakdown-8
Fuel pressure with pump on runs about 64psi. Then drops to about 50 psi after 10 minutes with pump off. No external leaks seen in fuel system
Thats only at the service port. I will have to check pressure at filter in the next few days
