99 odometer reads error
Old Feb 13, 2009 | 10:45 PM
smoothedoggie's Avatar
smoothedoggie is an unknown quantity at this point
Default 99 odometer reads error
my digital odometer displays the word error and my trip meter resets itself after every shutoff
sometimes the trip doesnt even work right like i might go 10 miles and it says i went 2 miles any ideas?
Old Feb 14, 2009 | 01:32 AM
cr8390's Avatar
cr8390 is an unknown quantity at this point
Default RE: 99 odometer reads error
would be nice to know what kind of truck you have....
Old Feb 14, 2009 | 08:55 AM
my bad 99 blazer 4.3 auto
Old Feb 14, 2009 | 04:38 PM
This is mostlikely caused by a faulty connection at the back of the cluster. You should pull the cluster and make sure everything is securely connected. Disconnect the wiring at the back of the cluster and inspect where the cluster side connector is soldered onto the circuit board. If there is damage in this area, you may be able to re-solder the connection and cure the problem, but it is likely that you will have to replace the cluster if damage is present.
shibbershabber
Feb 22, 2010 10:07 PM
Bl4z3r
Feb 10, 2009 08:39 PM
blazerguy22
Dec 12, 2008 07:59 PM
diggler149
Mar 30, 2007 09:05 PM
yashoo
Oct 1, 2006 02:38 AM
