About fog lights Chevy Blazer
Old May 20, 2009 | 02:11 PM
ebornand's Avatar
ebornand is an unknown quantity at this point
Default About fog lights Chevy Blazer
Dear, I am installing fog lights a 2001 Chevy Blazer with switch original, but I doubt if the BCM will capture the signal from the fog lights. So far I have not worked.
Anybody can help me?
Old May 20, 2009 | 02:45 PM
If you want them to work like factory, you will have to have the BCM programmed for the fog light option.
Otherwise, you can just wire them up to a relay and install another switch in the dash to turn them on.
Old May 20, 2009 | 03:57 PM
ebornand's Avatar
OK, What is the solution to leave the switch to light the original fog but independent of the BCM?
Old May 20, 2009 | 06:01 PM
The problem is that the fog switch is a momentary switch. You would need to setup a circuit that would keep track of the on/off state.
Much easier to wire in a new switch.
Old May 20, 2009 | 08:55 PM
ebornand's Avatar
I already see... and do you have some circuit idea?
Old May 21, 2009 | 10:21 AM
This can be done with a latching relay which will have two "relaxed" states. This type of relay can take the output from a momentary switch to toggle the load. You can also do this by wiring up a circuit using regular SPDT relays as detailed in the Latched On/Off... section on The12Volt.com.
You would still need to run wires to and from the relay...
Old May 21, 2009 | 10:13 PM
ebornand's Avatar
Thanks!!!
Old Jun 9, 2009 | 08:41 PM
ebornand's Avatar
Use the five relays, I made the connection according to www.the12volt.com, but not 100%, I mean
-When you turn on the Chevy Blazer neblineros automatically activated, the powering down and back on again but there are times when not working. What should be?
Old Jun 9, 2009 | 08:50 PM
No idea how you have it setup man... The schematic should work as shown on the12volt.com.
SWANNERZ
Aug 13, 2014 05:05 PM
Benedict1337
Dec 10, 2010 08:30 AM
tmurph01
Apr 13, 2010 02:27 PM
R2P
Nov 1, 2009 08:03 PM
ewingmh
May 13, 2007 07:21 AM
