ABS cutting in at low speed
Old Feb 10, 2010 | 05:40 PM
DaveHearne's Avatar
DaveHearne is on a distinguished road
Default ABS cutting in at low speed
Hi, my ABS sometimes cuts in just as i'm coming to a stop even though the wheels are not locking. I am pretty sure this is due to an excessive gap between the sensor & the toothed wheel on the hub (due to corrosion under the sensor mounting) as I have had the same problem on another vehicle I have owned. My question is - to stop it happening in the meantime, can I temporarily remove either the ABS fuse in the passenger or engine compartment fusebox until I can get round to removing the sensors & cleaning up the mounting surfaces in a couple weeks time when I have some time off work? Will I do any damage to anything by doing this? I am assuming the ABS warning light will come on to tell me that the system is disabled but the conventional braking system should remain operational?
Old Feb 10, 2010 | 05:53 PM
No damage, but the light will be on.
Pipewrench Dale
Nov 10, 2014 06:16 PM
hace1
Sep 8, 2011 08:43 PM
LioNiNoiL
Aug 4, 2011 02:47 AM
Brianator99
Oct 27, 2010 09:09 AM
