AC blowing hot air .. were talkin
Old Mar 13, 2010 | 02:15 AM
vze4yrte's Avatar
vze4yrte is on a distinguished road
Default AC blowing hot air .. were talkin
I found my answer by google but I'd like to hear something from you gentlemen.
just bought my truck I love it.. 1998 LT blazer 95000 miles
anyways the AC doesn't work.. it blows hot air whether I have the AC on , Fan on blows hot air in from outside etc.. how is the fixable? i do t k ow if this could make the truck over heat but i read about a Heater valve switch is open behind the glovebox?
Old Mar 13, 2010 | 08:50 AM
The repair depends on what is causing the condition and the equipment you have.
Do you have auto climate control?
When you turn on your A/C, does the compressor run at all? If you jumper the power & ground to the compressor clutch, does it cool?
Old Mar 14, 2010 | 06:32 AM
jojocarreno's Avatar
jojocarreno is on a distinguished road
Yes the part is called blend door actuator. New about $150. Not easy to get to, but you can get to it by pulling the dash down. It's kinda of square shaped and has a shaft going through it that opens the flapper for switching heat and cold air.
pettyfog
Apr 15, 2012 11:37 AM
Mandrwj
Apr 10, 2011 07:32 PM
97Bravada
Apr 17, 2010 03:46 PM
ravenhurst
15
Apr 26, 2009 07:53 AM
ItradeNDX
Feb 3, 2006 05:21 PM
