AC Guidance
I have a 1996 Blazer LT 4dr 4wd 4.3L engine.
Last Labor Day weekend, I noticed a light oil spray residue around the hose connector (aluminum 2-hose) on the top of the AC compressor. I pulled the compressor clutch wire so as to not cycle it.
Fast forward to now. I have replaced the O-rings on the connector and have borrowed a nice 2.5 cfm AC vacuum to clean the system. I will replace the dryer; but I have a question before going to get parts. Do I need to replace the orifice tube or will the AC vacuum remove whatever is there from it? The guy I borrowed the vacuum from says he hasn't ever replaced an orifice tube, but that the dryers do get clogged and need to be replaced.
I decided to replace the orifice tube with a variable tube. The AC on my blazer never did work very well (bought used with 50,000mi) and I was going to check the orientation of the tube when I replace it as I don't know who has worked on the AC before. After researching, it seems as though the short-end of the tube gets put into the evaporator first and the long end needs to be towards the condenser side. Any input would be helpful.
OffRoadNLovinIt
07-08-2013 12:48 AM
Vicer_Exciser
11-28-2010 09:54 PM
