AC Leak
Old Sep 7, 2011 | 12:29 AM
clbychil's Avatar
clbychil is on a distinguished road
Default AC Leak
My 99 Blazer quit cooling recently, I believe the freeon leaked out because a long while back i put some dye in and now there is some dye stain ontop of the compressor where the hoses connect. Is this a common problem and are there some sort of o rings or gasket that probably needs to be replaced?
Old Sep 7, 2011 | 01:01 AM
pettyfog's Avatar
That's unusual place for bad o rings. perhaps the last person who installed that coupling was sloppy.
You can get O rings for your compressor by model/year/compressor but I suggest that unless you have an evacuation pump which goes down to at least 27 in/hg, take it to a shop. They shouldnt charge much for that fix.
Old Sep 7, 2011 | 01:29 PM
neospyder's Avatar
neospyder is on a distinguished road
That's exactly where mine went bad. If the system has already leaked out all the freon why not just change the o rings yourself then take it in to be vacuumed and refilled? The o rings themselves only cost a dollar or two.
Old Sep 7, 2011 | 05:07 PM
pettyfog's Avatar
Suggest, though, if you do it yourself use a strong light and a magnifying glass if necessary and inspect very close for nicks or scratches in the o-ring seating area.
Understand that o-rings seal by operating pressure not just by squish. if there's a nick on the outer circumference of that recess it may leak again.
Same goes for the mating surface
Old Sep 7, 2011 | 07:45 PM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
I have read in a few posts that these pumps have a bad reputation for failing because of their bad design, I heard they fail internally tho and not where you talked about. it could be possible that you have a combination of both. Mine failed to, not sure where but but I'm getting a new pump at some point. Not too worried about it cuz I live in washington and our weather usually sucks lol.
Old Sep 14, 2011 | 07:23 PM
clbychil's Avatar
Due to the Dye stains on top it looks like it probably is where I'm talking about, the compressor works fine, its new, a backyard mechanic put it in for me and i think pettyfog is right about the sloppiness. It cooled fine for about 2.5 months then quit.
ComputerNerdBD
Aug 9, 2011 08:04 AM
BubbaBrooks
May 18, 2011 08:38 PM
abadinalbany
Jun 1, 2009 08:27 PM
TAZ454
Jan 28, 2008 10:11 AM
