ac stopped working need help please
Old Jul 10, 2008 | 10:30 AM
88blackzcand95blazer's Avatar
88blackzcand95blazer is an unknown quantity at this point
Default ac stopped working need help please
so about two week ago ac stopped working
- figured it was something small like a connection or fuse
- checked everything under the hood and got the compressor to kick on by "fiddling" with the low-pressure cycling switch connector to the accumulator
- ac worked fine for awhile but then stoped working again
- poped the hood again to check everything again but couldn't get it to run
- after pulling the fuse, ac started working again
- ac quit working again so i checked the connections in back of the instrument panel and under the dash, but everything looked good
- checked the "freon" level with a gauge and it was a little low
- jumped the low-pressure cycling switch to get the compressor to switch on and circulatesome new "freon"
- compressor clicked on and ac worked great but as soon as i disconnected the jumper wire and hooked the connector back up to the low-pressure cycle switch the ac failed to come on !
any help would be appreciated here
i am thinking it is the low-pressue switch ora relay but any info would be appreciated
thanks in advance!
Old Jul 10, 2008 | 11:02 AM
portcqb's Avatar
portcqb is an unknown quantity at this point
Default RE: ac stopped working need help please
Is the system up to operating pressure? If it is then that low pressure switch might be bad.
Old Jul 10, 2008 | 11:18 AM
yeah it is up to pressure i am thinking it is the low pressure cycling switch
i am wondering what is involved with replacing it, anybody know?
Old Jul 10, 2008 | 05:43 PM
update!
ac works again!
bought a "new" low pressure cycle switch from a junkyard for $2 and she is blowing cold again
without the info gathered here from other posts i would have been lost, thanks again
Old Jul 10, 2008 | 07:26 PM
Glad you found what you needed!
jstutzman
Dec 19, 2009 03:27 PM
acedrr03
TrailBlazer GMT360/GMT370 (2002-2009) Tech
Jan 17, 2008 10:37 AM
CamaroManBlack
Dec 8, 2007 12:10 PM
mac6135
Dec 8, 2007 09:18 AM
Stablock
Apr 20, 2007 04:29 AM
