Air Coming through Driverside Door
Old Jan 26, 2013 | 05:00 PM
Izzy207's Avatar
Izzy207 is an unknown quantity at this point
Default Air Coming through Driverside Door
I have a 1999 Blazer and for some reason air is coming through the driverside door. Any help on how to fix it and the cost for parts along with how to do the job would be greatly appreciated.
Thanks
Old Jan 26, 2013 | 06:53 PM
Where is it coming from? Around the door seal? Around the window track? Through the switch panel?
Old Jan 26, 2013 | 08:07 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Question
Given we have little info to guess on Im going to say the bottom rubber seal on the door has came of or you have a rust hole letting the air in.Can you give us some history about vehicles body condition and in general what are the air is coming from.
Old Jan 27, 2013 | 01:19 AM
Izzy207's Avatar
its is coming from the door jam. I have done some research and it seems as if the door jam pins needs to be replaced,
Old Jan 27, 2013 | 02:24 PM
4x4blazerguy's Avatar
You mean the hinge pins. That is very likely because that is a common issue with these vehicles. I found out it doesn't take much wear to cause water leaks. Only my top pin was bad & it caused a water leak.
Buy OEM pins & bushings. I bought a pin & bushing from Napa & the bushing didn't last. A friend is a body man & has been for 50 years & he says the same thing. He says the OEM fit much better than aftermarket. Since he works on this type of stuff & has done a great deal of paint & body work on high dollar classic cars over his career I'll believe him.
bobby099
Nov 20, 2012 09:32 PM
abig84
Jan 13, 2012 09:59 PM
dlippiet
May 13, 2011 11:27 AM
doc4663
Sep 27, 2009 09:46 PM
jsides
Sep 22, 2008 10:06 AM
