Air Conditioner Fan Setting #4 quit
The air conditioner/Heater fan setting #4 quit working yesterday in my 1998 Blazer. The other 3 settings still work.
What does this mean? Can I expect the other 3 to quit soon?
Generally does this mean the switch is bad? Fuse? or does the fan motor need replaced?
What are the costs? How hard is it to change? I have replaced the radio before so I know how to take the dash apart.
Any information will help.
High speed is a direct 12v feed to the fan motor through the blower motor relay. Swapping the relay with another on like it is a quick and easy diagnostic test. If that doesn't cure it, then you will need to test the voltages at the relay to see if the switch is working properly.
I seem to remember the relay being located behind the glove box.
dconnor.cfh
04-07-2012 10:48 AM
ktallman
12-16-2007 08:01 AM
brock
07-12-2007 06:14 PM
