Air Conditioning Electrical Problem
Old Apr 13, 2008 | 08:26 PM
DrThorsen's Avatar
DrThorsen is an unknown quantity at this point
Default Air Conditioning Electrical Problem
I have a 2WD 2001 S10 Blazer LT and am having an electrical problem with the A/C. I'm getting no power on my meterto the compressor clutch to fire up the system. I've checked the fuses in the dash and engine compartment and all are good. If I manually close the A/C relay in the engine compartment with a paper clip, the A/C fires up and works great. I suspect there's some problem indash switch, but my Haynes manual provides no schematic for the HVAC system nor any break out of the dash electrical controls. Anyone have a schematic or knowledge of the system? Encountered a similar problem?
Old Apr 13, 2008 | 09:07 PM
stevenray623's Avatar
stevenray623 is an unknown quantity at this point
Default RE: Air Conditioning Electrical Problem
my guess is its low on freon , put some gauges on to check the pressures or take toa shop.
Old Apr 14, 2008 | 10:41 AM
DrThorsen's Avatar
I checked the freon level, it's fine. The systems works perfectly once engaged so I'm fairly certain the problem is not with the A/C system itself, but rather the electrical.
Old Apr 14, 2008 | 10:46 AM
Sounds like you have a sensor problem. Mostlikely the pressure sensor which is located at the filter/dryer (large silver canister in front of the firewall on the passenger side).
Casole6
Jun 30, 2012 07:42 PM
dannydblazer
May 23, 2011 09:48 AM
akustom57
Jun 4, 2010 07:18 AM
littleblueblazer
May 24, 2009 04:14 PM
myboo11009
Aug 22, 2006 04:21 PM
