Air leak?
Old Feb 25, 2019 | 11:05 AM
Did you have any other symptoms to confirm the pump was at fault? E.g. pressure drop in the fuel lines after ignition switch turned off?
I keep coming back to what could blow off the duct as an indication that something else is wrong. The fuel injection "spider" under the intake plenum (on which the throttle body sits atop) can leak allowing fuel to accumulate below the throttle body.
Old Feb 25, 2019 | 11:26 AM
ouwee's Avatar
ouwee is on a distinguished road
I didn't check the pressure, I just went ahead and change the pump. It was a cold morning when duct blew off upon starting it, could that be a cause?
Old Feb 25, 2019 | 11:48 AM
How cold is cold to you? I've started mine when it was 15'F (and perhaps colder) with no problems.
I'm a big fan of knowing why I am replacing a part before doing the replacement. It is possible that the fuel pump was bad and replacing it helped address the fundamental problem. It is also possible that the fuel pump was fine and it was just a coincidence that the other symptoms seemed to change at the same time. (BTW, these fuel pumps tend to eventually fail so replacing it was at worst a preventative measure.) It is also possible that there is still something else going on.
Old Feb 25, 2019 | 11:58 AM
ouwee's Avatar
It was about 28 degrees that morning. No, replacing the fuel pump had nothing to do with the current issue. The duct blew off the morning I was getting ready to change the fuel pump, before I changed the fuel pump.
Old Feb 25, 2019 | 04:01 PM
In your original post you said you could hear air being sucked in somewhere, is that still the case? That you had this pop off, apparently with enough force for the wingnut to be lost to me sounds like something bad going on. I'm running out of suggestions besides taking off the duct between the throttle body and the air filter and doing a thorough visual check of it and everything else on the intake plenum. Also grab the throttle body and try to move it to ensure it is all secure.
Old Feb 25, 2019 | 04:15 PM
odat's Avatar
My bets he broke the nut, the air plenum didn't blow off it vibrated off, And the sound may just be the clutch fan noise as its running
Old Feb 25, 2019 | 04:28 PM
CWBDDSPC's Avatar
CWBDDSPC is on a distinguished road
+1
Are you having any drivability issues with the vehicle? Check engine light on?
Old Feb 27, 2019 | 01:02 AM
Doms13's Avatar
Doms13 is on a distinguished road
And how is your problem? Did you manage to fix it?
_____________________
http://www.dsmtech.pl/en/poppet-type-damper
Rodney V
Oct 24, 2016 06:55 AM
kelcan
May 27, 2014 11:28 PM
upmaine
Apr 15, 2010 06:52 PM
94camaro
Performance & Brainstorming
Dec 15, 2008 02:15 PM
BlazerSS
Headers, Intake, & Exhaust
Apr 12, 2007 08:18 PM
