Airflow control is not working
Old Oct 18, 2013 | 01:36 PM
hans109h's Avatar
hans109h is on a distinguished road
Good to hear, thanks for following up.
Old Nov 1, 2013 | 11:23 AM
jcmartin0313's Avatar
jcmartin0313 is on a distinguished road
Default Message you for help
Originally Posted by austrochevy
Thank you very much for the tips! I've replaced the vacuum lines and it works now.
I have the same problem. Can we message and you tell me how you replaced the lines? I am new to my Blazer and pretty uninformed.
Old Mar 18, 2022 | 09:50 PM
Krash6366's Avatar
Krash6366 is on a distinguished road
Default 1996 hvac vacuum routing
1996 blazer. HVAC was stuck on defroster mode. All actuators were connected. I located the main vacuum line coming in behind the dashboard was disconnected where it transitions from the black line to the gray line that goes to the control ****. I cut a square a hole out of the left side of the glove box to get a better look inside. I could not determine where the gray line connected it had a right angle connector on the end of it. I made a smoke machine from a video I watched on YouTube and I was able to find The line that came from the firewall going across the inside of the passenger compartment deep inside the dashboard. It was in a bundle of wires pretty much straight in and towards the top of where I could see through the hole in a glove box.. The Smoke machine helped me locate the The disconnected small diameter vacuum line that came from the engine compartment. I hope this helps somebody. The homemade Smoke maker was a very cheap tool to make and it worked very well at locating where the vacuum leak was.
Blower motor, fan control and temperature is working but air will come primarily from the instrument panel
Old Nov 10, 2024 | 07:41 PM
Blazerbabe96's Avatar
Blazerbabe96 is on a distinguished road
Question
Originally Posted by hans109h
Right in the same area the vac hose that goes to the firewall there is a three way splitter on the lines, there is usually one really short piece of tube that wears out really quick, check it for any cracks. Basically if you touch the line and it instantly turns your hand completely black, it's time to replace the lines.
If this isn't your problem, then you might have to pull the dash and check for vaccuum at the controls.
The small tube you're talking about where does it plug into because that is where mine has seems to be disconnected from the small tube is not connected to anything or is it supposed to be
Attached Thumbnails Airflow control is not working-1731289246428632765642296126772.jpg
Old Nov 11, 2024 | 08:06 AM
hans109h's Avatar
That's the line that goes to the nipple inside the fender to the rear of the abs module. Slide your hand along the driver's side edge of the engine compartment, you'll find it.
Old Nov 11, 2024 | 02:31 PM
puttster's Avatar
Here's a link to my (similar) issue. I have a 2002, so the info might not help. https://blazerforum.com/forum/2nd-ge...d-hose-102386/
big_charms@hotmail.com
Mar 20, 2014 10:26 PM
EuroGoldLS
Headers, Intake, & Exhaust
Mar 25, 2007 01:33 PM
ilikebread
21
Mar 29, 2006 11:30 PM
2001Blazer4x4
Dec 3, 2005 04:17 PM
BlaZeR FXB1581
Nov 13, 2005 03:41 PM
