Airplane Noise
Old Mar 26, 2011 | 03:34 PM
kyjonesy's Avatar
kyjonesy is on a distinguished road
Default Airplane Noise
I have a 98 Chevy Blazer 4door 4x4. I just got the vehicle a couple months ago and so far have replaced: Intake gasket, valve cover gasket, both front axle and hub bearings, new vacuum switch, rear diff gasket, front diff fluid, thrust washers, oil change, and a tranny filter and fluid is in the near future. I have this horrible airplane noise that starts around 25-30mph. The faster you go (obviously) the louder and higher pitched the noise gets. My mechanic said it was possible the luggage rack was causing the noise, but after moving the racks around still no change. I noticed while adjusting the crossbars on the rack that they are shaped similar to an airplane wing, but the skinny part of the bar is facing the back of the vehicle. Its like this on both bars. Was just wondering if anyone knew if they were on backwards or if their installed correctly, or if anyone might have an idea whats causing the noise.
Old Mar 26, 2011 | 03:46 PM
ffox's Avatar
ffox is on a distinguished road
I've got a 93 and it's facing the same as yours, thin part to the back..Could it be the radio antenna?
Old Mar 28, 2011 | 03:47 AM
kristoph30's Avatar
kristoph30 is on a distinguished road
Thios is going to sound like a stupid question: What type of airplane? A prop job or a jet? Prop job could be from the front axle splines partially engaging or if its a jet the something is in the air stream.
Old Mar 28, 2011 | 04:32 PM
step66's Avatar
Hello! Why haven't you checked the fan clutch?
Old Apr 3, 2011 | 01:41 PM
kyjonesy's Avatar
sorry i havn't posted back in a couple days....its more similar to a jet, but more like a whirring sound. it's not the fan clutch, if it was it would be RPM dependent and not speed dependent. I realize that its probably something in the airstream of the vehicle, however there was no noise the first 2 weeks i had the vehicle, and nothing has changed in the body lines. only exterior alteration was fog lights, but it was making the noise before i put them on.
Old Apr 3, 2011 | 04:02 PM
Does the noise change if you're driving 35 or so mph and change lanes quickly? Just because a hub assembly is new, doesn't always mean it's good.
dj00140
Apr 13, 2011 10:40 AM
RhysThePiece
Mar 25, 2011 11:40 AM
streblo
Jan 5, 2011 12:42 PM
50andFlyFishing
Sep 8, 2009 11:34 PM
farleyeod
Apr 4, 2009 07:32 PM
