Annoying Problem
Old May 20, 2010 | 08:42 PM
ethangerhardt2@yahoo.com's Avatar
ethangerhardt2@yahoo.com is on a distinguished road
Default Annoying Problem
When i first start my blazer and pull out of the driveway and get on the gas it falls right on its face. It backfires and studders. After driving around for a little bit the problem goes away and it drives just fine. Ive replaced the fuel pump and fuel filter so those are both good. I changed the plugs and wires last spring. One thing i didnt change was the cap and rotor. I dont know if that would do it or not. Its a 1996 chevy blazer. Any info on what it might be or where i should start. Thanks
Old May 20, 2010 | 08:51 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
do you have any codes? it really sounds like a fuel issue to me but i could be wrong
Old May 20, 2010 | 09:03 PM
Nope check engine does not come on. I do have one of those ported throttle bodys with the lighter buterfly in it.
Old May 20, 2010 | 09:16 PM
could be a spider injector assembly leaking
Old May 21, 2010 | 11:08 PM
Is there a way you can tell if the injector is leaking.
Old May 22, 2010 | 07:40 AM
you can do a injector leak down test, but you will need a fuel pressure gauge and a injector tester. otc sells them.... http://www.otctools.com/products/fue...n_pulse_tester
iamchevyman5
Feb 9, 2011 07:17 AM
LittleT
Oct 4, 2007 09:32 AM
timetoblaze
Jun 2, 2006 01:17 PM
Patrick
Jan 22, 2006 12:35 PM
mkatts
Sep 6, 2004 10:54 PM
