another hvac question
#41
Does it leak out of another port? If so, which one?
#42
it leaks out of number 3, not sure of color since dash is back together. but if your looking at a back view of the mode switch, its at the 9 oclock position on the inside of the two
#43
In the vacuum connector at the mode switch, connect the vacuum pump to the red vacuum line, apply vacuum and see if it holds.
#44
#45
In the connector, with the mode switch unplugged.
#46
#47
Red tested fine, if anything it dropped less than a quarter but i could be going senile at this rate haha....
This morning i had time to test it again....both on ac and then heat for every mode....max ac ac and bi level worked perfectly, only a small amount came from defrost vent then when i started driving it didnt come out of defroster...the only thing that didnt work was floor it also came out of defroster but i can live with that i never use foot only....when off is selected....it still comes out of defroster vent
Testing was with old unit too
#48
redid the test on all vacuum lines...heres my results by what number port the color corresponds to (after 10 minutes is second number)
1 Orange 20 -20
2 Red 20-19.5
3 Yellow 20-17
4 Brown 20-20
5 Blue 20-19.75
6 Black 20-20
1 Orange 20 -20
2 Red 20-19.5
3 Yellow 20-17
4 Brown 20-20
5 Blue 20-19.75
6 Black 20-20
#49
OK, that's good. No leaks in the lines or actuators. As you're applying vacuum to each line, make sure each actuator operates its linkage, and the door actually moves.
#50
Red-vents ( lightly defrost and floor)
Orange- high vents (assuming max ac)
Brown- defrost/floor (light vent)
Yellow- floor (light defrost)
Blue- vents (light defrost and floor)
