Antifreeze Leaking. Need Help.
Old Jun 1, 2010 | 10:13 PM
Jimmy91's Avatar
Jimmy91 is on a distinguished road
Default Antifreeze Leaking. Need Help.
So i had just replaced my water pump as antifreeze was leaking from it and then everything was fine for about 1 1/2 months. Then it started to leak off and on and i was always having to refill my antifreeze. All the hoses are fine and there are no cracks in the radiator. When i was driving it the heat gauge stayed the same as what it always is.
Just wondering if anyone has any thoughts?
Thanks
Old Jun 1, 2010 | 10:34 PM
danmiranda's Avatar
danmiranda is an unknown quantity at this point
You are sure its not the radiator? I found hairline cracks in mine causing leaking on the less visible side. Check the hoses themselves for leaks themselves too for a start, both upper and lower.
Old Jun 2, 2010 | 04:00 PM
rdlyn's Avatar
rdlyn is on a distinguished road
are there puddles? did you check to see if the intake manifold area is wet, particularly in back? Just a thoughtl....
craig1319
23
Jul 6, 2018 11:26 PM
Bowtiebaby
Aug 25, 2011 12:21 AM
FoxTrota
Jan 22, 2009 06:04 AM
Blazer4U
Oct 24, 2008 04:03 AM
Dwarf415
Jun 16, 2006 01:23 PM
