Any ideas??
Old Oct 5, 2015 | 01:28 PM
wheeliemay's Avatar
wheeliemay is on a distinguished road
Default Any ideas??
I've had this wet area on the passenger side for over a year now. It doesn't mark up the driveway, but it's a mystery to me so I wanted to post up some pics (links) and get some feedback. It is the area where the CV connects to, well, whatever it connects to--the hip bone?
https://i.imgur.com/vGemIIC.jpg
https://i.imgur.com/bLCMtZ7.jpg
https://i.imgur.com/5v9Rx6H.jpg
BTW...it's an `01 Bravada
Old Oct 5, 2015 | 02:38 PM
Appears to be the seal for the half shaft. The half shaft will need to be removed to replace the seal. Make sure the front differential fluid level is correct by removing the upper, (fill) plug. Should be even with the bottom of the hole.
Old Oct 5, 2015 | 03:06 PM
wheeliemay's Avatar
Thanks Captain. So, am I checking it to be sure it is not running low from the leak? (makes sense) More importantly, is there a writeup on this?? Or, should I just pay a shop?? Thanks
Old Oct 5, 2015 | 06:42 PM
Very important that the differential has sufficient fluid, (80W90). If it runs out, and the differential seizes up, your DIY job went from $10 to a few hundred! Fair amount of work to remove & install the half shaft, (1.5 hours) but once it's out, replacing the seal is a 5 minute job. Seems like I saw thread for replacing the half shaft here on the forum.
Old Oct 6, 2015 | 11:15 AM
wheeliemay's Avatar
The fluid level is good. I will search the forum and see if I can come up with some more details.
alamantia
Headers, Intake, & Exhaust
Jan 21, 2010 05:20 PM
bjsx8f
Oct 26, 2009 11:29 AM
gizwilly
Sep 5, 2007 11:08 AM
The Franchise
Mar 10, 2007 10:54 PM
hicksjw
Jan 10, 2007 04:32 PM
