Anyone know about transfer cases??
Old Nov 17, 2014 | 04:07 PM
I think what you're referring to is the input shaft seal of the transfer case leaks and fluid from the automatic trans gets pulled into the transfer case. Engine oil can't get into the transmission.
The fill plug on the rear differential is on the passenger side, forward of the axle tubes. It's about the same height as the driveshaft, and is just above a "ledge" on the differential housing. You use a 3" long 3/8" extention to remove and reinstall the plug, (no socket required).
Old Nov 17, 2014 | 04:20 PM
coeltonbozz's Avatar
coeltonbozz is on a distinguished road
Yeah after I said that I'm thinking its just really old trnansmission fluid that's never been changed and awesome thank you ill go look for the plug on the rear diff bbut it could do all this just because the tranny had lost all the fluid? Danm I'm an idiot
Old Nov 17, 2014 | 08:29 PM
Your manual transmission has seals on both the input & output shafts. Not likely that the trans fluid is migrating to the transfer case. Pull the differential cover off and have a look inside. Gasket is a few bucks, and you'll need about 2 quarts of 80W90 gear lube.
Old Nov 18, 2014 | 09:00 AM
Yeah I plan on pulling it today to check it out also open the shifter so I can look at the top of the tranny
Old Nov 18, 2014 | 07:43 PM
Ok so I got am update I would like an opinion .. pulled the diff cover off gears look fine know broken gears I saw. Drained the tranny fluid "there was about 2 3 quarts still in it. Tommarows going to be hooking the transfer case back in top the fluids off and try it out do you think there's anything else you could think to check before I do put it back on?
Oh and I did nedd a ratchet to get the fill plug off the rear diff
gordonltaghon
15
May 14, 2013 06:25 PM
oldsbravada2000
Jan 1, 2013 05:23 AM
green dot
Jul 9, 2012 02:39 PM
root'n
Sep 16, 2009 06:27 PM
kec70nova
Mar 29, 2007 04:18 AM
