Auto 4wd vs standard electronic 4wd trasnfer case
Old 06-01-2014 | 05:43 PM
Question Auto 4wd vs standard electronic 4wd trasnfer case
Quick random question. Does the transfer case in the Blazers with the auto 4wd button suffer the common issue of fluid getting pass the seal and sucking up into the vacuum lines, or is that only an issue with the non auto option transfer cases?
I would only assume that the transfer cases are different between the two, but is the problem common between both?
I only ask because I could have sworn I read it somewhere that it's not an issue if you have the auto 4wd but I cannot dig it up anywhere again... I'm not having issues with mine, I have an 04 with the auto option, I'm just curious.
Thanks
LesMyer
06-05-2024 09:23 AM
PanthersBlaZ
09-17-2012 12:59 PM
Straka88
14
11-12-2011 03:08 PM
Lilcheef
07-04-2007 06:18 PM
4WD Rookie
03-06-2006 10:41 PM
Quick Reply: Auto 4wd vs standard electronic 4wd trasnfer case
