Axle Nut
Old Jun 25, 2012 | 03:24 PM
50percentgenius's Avatar
50percentgenius is on a distinguished road
Unhappy Axle Nut
So I wasn't exactly sure where to post this. But here goes.
I'm getting ready to install new upper control arms with ball joints and lower ball joints. I went to loosen the axle nuts after using some liquid wrench and one bolt loosened up just fine. The other was being a pain. Through much tugging and any way I could think of to loosen the bolt, I ended up bending the breaker bar, then later breaking it to the point of uselessness. Any ideas how to remove this bolt? I have no access to air tools as of now.
Old Jun 25, 2012 | 03:35 PM
warthogdriver's Avatar
i would pb blast it.
i have always removed the center cap to access the nut with the wheels on just to break it free...with a jack in place of course to be extra sure.
then once its loose slightly i go about jacking, bracing and removing everything.
Old Jun 25, 2012 | 03:44 PM
Yeah that's how I got the other one off. I'm pretty sure someone torque this down for the wrong specification. I'm gonna go get a new breaker bar later and maybe put a pipe on it. And PB blaster because I ran out of my current bolt loosener .
Old Jun 25, 2012 | 03:57 PM
yeah...sometimes you need to break out the 3 foot pipe.
sounds like someone was impact gun happy....i think those only get torqued to somewhere around 100 ftlbs...give or take. i cant think of actual number right now.
i would spread some anti seize on it when your done. i use that stuff everywhere...it makes life so much easier down the road.
Old Jun 25, 2012 | 03:59 PM
Yeah I'll get some of that as well. I was betting they just tightened it until the impact stopped.
My Dad is grabbing me a new breaker bar and is gonna try and help loosen it while I'm at work tonight.
Old Jun 25, 2012 | 05:44 PM
war00's Avatar
war00 is on a distinguished road
propan torch and prop it up and leave there for 15-20mins than spary with pb and try an take it off than. usualy works for me on stubborn nuts and bolts when im working at home.
Old Jun 25, 2012 | 11:30 PM
Click on that
That did the trick for sure!
myblackblazer
Mar 22, 2011 04:41 PM
TheCackster
Nov 22, 2009 11:24 AM
Bojib
Mar 30, 2008 11:41 AM
frankjc
Suspension Tech
Sep 10, 2006 04:56 PM
98Blazer
Feb 15, 2006 05:40 PM
