bad fuel filter?
bad fuel filter?
sorry about this i am new to the blazer world i just got out of the dsm scene .ok i think my fuel filter is shot i have a 2000 blazer ls with the vortec v6 in it and i noticed my gas milage is shot i filled it up and 175 miles later i need more is this normal or is my fuel filter shot?
RE: bad fuel filter?
Well I wouldnt jump right to the conclusion of a bad fuel filter. A lot of people would suggest things like clean your egr valve. Is your cat bad, does your exaust smell? When was the last time the thing had a general tune up? Tire pressue good? Air filter good? Fuel filter clean (you may notice poor acceleration or hesitation if this is bad)? Are you stuck in 4x4 and you dont know? There are a ton of other things I missed out, and this is just to get you started. But others that respond to this will probably inform you about more technical issues you may have that I left out.
Don't forget our wonderful winter fuel, (WinterBlend) will drag your mpg's down....
Also how much fuel do you put in it when you fill up? My fuel light comes on when I have 5 gallons left in my 18.5 gallon tank. Could be you gauge does not read correctly like mine. Korey.
My 95 mileage took a dump this past week from an average of 15mpg all fall and early winter to 13mpg driving the same roads etc...Have to think it is the fuel as it is running well.
it is sluggish when i get on it at first but then it powers up my cat isnt bad i think no bad exhaust smell my right front tire is choppy so i need to get that replaced. i want change plugs fuel filter and air filter and replace it with a k&n filter does the k&n help gas milage. what plugs would u reccomend?
AC Delco Plats n a Bottle of Fuel Injector Cleaner
would the k&n air filter help at all??
Yes, they are very good in longevity and perform well, i run one in my jimmy
bigdaddykane93
06-25-2012 02:24 AM
95jblaze
08-27-2011 04:46 PM
brianroark
06-25-2010 04:14 PM
Chalz
12-04-2008 07:11 PM
riverjamie
09-24-2007 09:21 PM
