Balance shaft question
Old May 18, 2011 | 06:22 PM
Chevy33's Avatar
Chevy33 is on a distinguished road
Default Balance shaft question
I have a 1999 Blazer 4x4 4.3 with the balance shaft. I had the machine work done and the tech installed all the bushings for the cam and rear balance shaft. When tearing down the motor I neglected to loosen the timing gear from the balance shaft prior to removing the timing chain. Behind the upper timing gear on the balance shaft there is a bearing will ball bearings. What is this part named? I would like to replace this in my build however when looking for new parts at Rockauto.com it would appear they are calling the rear bushing a bearing and I have not found the ball bearing part I am seeing on my balance shaft. I will be looking over my manual for this part name so if you can help with this information Thank you in advance.
Old May 18, 2011 | 07:05 PM
Item #135 from THIS SCHEMATIC. GM OE PN 10105908. The schematic states that this is part of the balance shaft.
Old May 20, 2011 | 06:45 AM
Chevy33's Avatar
Default Good information
Thanks for the great information.
Old Jun 30, 2011 | 08:43 PM
Chevy33's Avatar
Default Bearing found at dealer
This bearing was displayed on the Compnine.com website as a part. I purchased mine from a dealer.
Old Nov 28, 2011 | 08:32 AM
Chevy33's Avatar
Default I'm on my second 98 rebuild
On this build I ordered this bearing online. I paid $11.73 and that included shipping. This original NSK bearing is stamped with the number 6006 N. In searching for this same bearing I found that the bearing I needed to order is 6006 NR, the R denoting the lock ring on the outer race.
http://www.bearingsdirect.com/store/...duct_list&c=49
30mm x OD: 55mm x W: 13mm Snap Ring over Ball Bearing with Selection of Rubber Sealed & Open
I bought mine through Amazon.com
2000blaze
Dec 23, 2013 06:22 PM
piscespokerbrat
Apr 21, 2012 11:58 AM
noon_crue
Jul 19, 2009 08:39 PM
4speed
Oct 16, 2008 09:38 PM
brunosrk
Sep 21, 2007 02:58 PM
