Ball joint torsion bar quick question
Old Jan 20, 2013 | 04:12 PM
newguy's Avatar
Default Ball joint torsion bar quick question
When raising your front end cranking the torsion bar which ball joint is more apt to go first, upper or lower?
Old Jan 20, 2013 | 06:29 PM
When you increase or decrease front chassis ride height out of spec, you are asking the suspension and steering linkage to do something it was not designed to do. It will cause premature wear on all 4 ball joints, both outer tie rod ends, both front shocks, both torsion bars and all 4 CV joints. It will also affect wheel alignment, handling and braking. Not a smart idea to mess with it If you want the body higher, do a body lift.
Old Jan 20, 2013 | 06:46 PM
newguy's Avatar
thanks Captain
richphotos
Mar 11, 2012 11:44 PM
tydaug
Apr 18, 2009 05:05 PM
tt0876
Suspension Tech
May 5, 2008 11:32 AM
