Battery disconnect and radio issues
Old Feb 1, 2009 | 02:47 PM
Tony H's Avatar
Tony H is an unknown quantity at this point
Default Battery disconnect and radio issues
OK obviously its no big deal if I lose my preset stations but if I disconnect the battery, Is there some anti theft deal that I need to know to get the radio to work again? I know many newer cars have this.
Old Feb 1, 2009 | 05:09 PM
Mammys Car's Avatar
Mammys Car is an unknown quantity at this point
Default RE: Battery disconnect and radio issues
Probably.
Check the owner's manual. There's a procedure to turn off the lock out 'feature' (total PITA) that's easy to do. I'd print it but don't have access to the book just now. One of the first things I did upon purchasing my neighbor's used Blazer was to disable that 'feature'
Good luck.
Old Feb 1, 2009 | 05:47 PM
SockJock's Avatar
SockJock is an unknown quantity at this point
I'm sure your blazer was equipped with the "theftlock" feature and if it hasn't already been turned off by the dealer it could cause issues when disconnecting the battery, and the dealers like to sock it to you just to disable or reset one that has been theftlocked. Best bet would be to check the owners manual and disable it first before disconnecting the battery and then leave it disabled when you're done just in case of future power failure.
Old Feb 2, 2009 | 08:48 AM
Tony H's Avatar
That would be great but I don't have an owners manual. My daughter bought this second hand.
I will have to rig up some clips to the battery to keep power to the system. I need to pull teh battery Tray to 'f' around with this ridiculous 4WD system. Give me solid front axles any day
Old Feb 2, 2009 | 09:31 AM
Megalodon_Al's Avatar
Megalodon_Al is an unknown quantity at this point
This is directly out of the '99 Blazer owner's manual.
Hope it helps.
Theft-Deterrent Feature (If Equipped)
THEFTLOCK
is designed to discourage theft of your
radio. It works by using a secret code to disable all radio
functions whenever battery power is removed.
The THEFTLOCK feature for the radio may be used or
ignored. If ignored, the system plays normally and the
radio is not protected by the feature. If THEFTLOCK is
activated, your radio will not operate if stolen.
When THEFTLOCK is activated, the radio will display
LOC to indicate a locked condition anytime battery
power has been interrupted. If your battery loses power
for any reason, you must unlock the radio with the secret
code before it will operate.
Activating the Theft
-Deterrent Feature
The instructions which follow explain how to enter your
secret code to activate the THEFTLOCK system. It is
recommended that you read through all nine steps
before starting the procedure.
NOTE: If you allow more than 15 seconds to elapse
between any steps, the radio automatically reverts to
time and you must start the procedure over at Step 4.
1. Write down any three or four
-digit number from
000 to 1999 and keep it in a safe place separate from
the vehicle.
2. Turn the ignition to ACCESSORY or RUN.
3. Turn the radio off.
4. Press the 1 and 4 buttons together. Hold them down
until
- shows on the display. Next you will use the
secret code number which you have written down.
5. Press MN and 000 will appear on the display.
6. Press MN again to make the last two digits agree
with your code.
7. Press HR to make the first one or two digits agree
with your code.
8. Press AM
-FM after you have confirmed that the
code matches the secret code you have written down.
The display will show REP to let you know that you
need to repeat Steps 5 through 7 to confirm your
secret code.
9. Press AM
-FM and this time the display will show
SEC to let you know that your radio is secure. The
LED indicator by the volume control will begin
flashing when the ignition is turned off.
Unlocking the Theft
-Deterrent Feature After a
Power Loss
Enter your secret code as follows; pause no more than
15 seconds between steps:
1. Turn the ignition on. LOC will appear on the display.
2. Press MN and 000 will appear on the display.
3. Press MN again to make the last two digits agree
with your code.
4. Press HR to make the first one or two digits agree
with your code.
5. Press AM
The display will show SEC, indicating the radio is
now operable and secure.
If you enter the wrong code eight times, INOP will
appear on the display. You will have to wait an hour
with the ignition on before you can try again. When you
try again, you will only have three chances to enter the
correct code before INOP appears.
If you lose or forget your code, contact your dealer.
Disabling the Theft
-Deterrent Feature
1. Turn the ignition to ACCESSORY or RUN.
2. Turn the radio off.
3. Press the 1 and 4 buttons together. Hold them down
until SEC shows on the display.
4. Press MN and 000 will appear on the display.
5. Press MN again to make the last two digits agree
with your code.
6. Press HR to make the first one or two digits agree
with your code.
7. Press AM
-, indicating that the radio is
no longer secured.
If the code entered is incorrect, SEC will appear on the
display. The radio will remain secured until the correct
code is entered.
When battery power is removed and later applied to a
secured radio, the radio won’t turn on and LOC will
To unlock a secured radio, see “Unlocking the
Theft
-Deterrent Feature After a Power Loss†earlier in
this section
Old Feb 2, 2009 | 12:55 PM
rriddle3's Avatar
ORIGINAL: Tony H
Register your VIN atGM Owner Centerand you can download a .pdf of your owner's manual.
Old Feb 16, 2009 | 09:30 AM
Tony H's Avatar
Thanks All I got an owners manual. They talk more about Child car seats than Light bulb part numbers and Tire sizes.. weird.
Anyway. I read the whole Theft detterent thing that was nicely listed above by Megalodon_Al.
Notice it says nothing about how to turn it off if you DON'T know the code. There is no mention on some Display lamp indicator showing that it is Activated.
I took a shot, unplugged the battery and all was good. Whew.
Old Mar 4, 2009 | 09:35 PM
zackoch's Avatar
zackoch is on a distinguished road
I could never find my code... I have that delco theftlock. Thank god, I've never had any trouble with it locking itself
law13man
33
Jun 21, 2014 04:47 PM
Brian5792
Jun 26, 2013 12:57 PM
BaLListic_Evo
Jun 6, 2010 09:23 AM
punx.inc
Mar 28, 2009 04:06 PM
punx.inc
Jan 20, 2009 12:48 PM
