battery disconnect switch
Old Dec 28, 2008 | 04:15 PM
punx.inc's Avatar
punx.inc is an unknown quantity at this point
Default battery disconnect switch
im just curious on battery disconnect switches. i would like one that i can put in the cab, instead of one that is ON the battery. anyone recomend any brands or methods? just trying to get some info on this.
Old Jan 20, 2009 | 12:44 PM
DdayK5's Avatar
DdayK5 is an unknown quantity at this point
Default RE: battery disconnect switch
Do you want the battery to disconect or the ignition switch (prevent theft). They make relay's or solinids to disconect the battery from the system so you don't have to run a battery cable into the cab. If you want a battery disconect for safety reasons you could shop around for a relay or solinoid to put inline with a battery cable to open the circut then you run a swith to the cab to control the solinoid. To prevent theft you can have a hidden switch or button in line with the ignition switch to only alow power when you want to start the engine.
Old Jan 20, 2009 | 12:48 PM
DdayK5's Avatar
http://www.mgexperience.net/article/...t-switches.pdf
The web as some interesting ideas.
Brian5792
Jun 26, 2013 12:57 PM
BaLListic_Evo
Jun 6, 2010 09:23 AM
punx.inc
Mar 28, 2009 04:06 PM
Tony H
Mar 4, 2009 09:35 PM
Marcin
Nov 26, 2006 08:35 PM
