battery draw (need help asap)
Old 04-05-2008, 05:23 PM
rwrows's Avatar
rwrows is an unknown quantity at this point
Default RE: battery draw (need help asap)
awesome just found it. factory stereo. ok. the RDO BATT is pulling the most draw. ???
Old 04-05-2008, 05:25 PM
rwrows's Avatar
i could be wrong about the .75 amps, i have the tester set to 10A and i'm getting a reading of .64 or so on the RDO BATT. so maybe that is 6.4 amps??? sorry for my ignorance.
Old 04-05-2008, 05:27 PM
drperry's Avatar
Setting it on 10 amps, .64 should be .64...
Check for the fuse for the under hood light, if you have one...
Old 04-05-2008, 05:30 PM
rwrows's Avatar
there's no light bulb installed under the hood. also, the draw seems to jump up and down, when i first make contact with the leads the ams go up to 1.5 and then go down to .6 or so. ???
Old 04-05-2008, 05:32 PM
drperry's Avatar
Did you try pulling some of the interior fuses to see if you could get it to stop?
Old 04-05-2008, 05:35 PM
rwrows's Avatar
yes i've narrowed it down the RDO BATT fuse. that's definately the circuit that's drawing. any clue on my next move???
Old 04-05-2008, 05:38 PM
drperry's Avatar
Pull the fuse, and see if it stops the problem... If not, your draw is somewhere else.
If it does fix the problem... Get your alternator and battery tested, lol.
Old 04-05-2008, 05:46 PM
rwrows's Avatar
the fuse is currently out. and battery draw is normal <.1 amps. what does this mean?
Old 04-05-2008, 05:50 PM
rwrows's Avatar
what is the atc fuse??? that's not istalled under the hood. i installed it and i hear a click inside the cab somewhere. ???
Old 04-05-2008, 09:50 PM
WolfPack's Avatar
Could he have a bad door switch? Causing the radio to stay on...what about your interior lights? Do they work fine?
Quick Reply: battery draw (need help asap)
