battery draw (need help asap)
Old Apr 24, 2008 | 06:41 PM
  #31
rwrows's Avatar
rwrows is an unknown quantity at this point
Default RE: battery draw (need help asap)
i thought the average draw with the key off is 100 mA. Well I have a draw at 600 mA. It's a brand new battery. It got weak after sitting for 3 days. Unless i pluck the fuse, the battery will get week after sitting a few days.
Old Apr 24, 2008 | 06:47 PM
  #32
drperry's Avatar
I can't seem to figure out what IPC is
Old Apr 24, 2008 | 06:54 PM
  #33
rwrows's Avatar
Instrument Panel Cluster (speedo, odo, tach, shift indicator)
Old Apr 24, 2008 | 07:05 PM
  #34
drperry's Avatar
Unplug the cluster itself... You'll see if there's a short in the wiring or the cluster... I think.
Old Jul 24, 2008 | 11:23 PM
  #35
sidewheeler's Avatar
sidewheeler is an unknown quantity at this point
OK I know that this thread was done in april of this year but I also have a battery drain problem. after reading all of these replys I think Wolfpack may have hit on the problem. he asked if the door switch was working or not. Now my problem is a drain caused by the digital clock staying on when the key is turned off. The interior lights work properly, but if I leave the car setting for a week it will have a dead battery. If I pull the fuse that controls the clock I also loose my radio and have to reprogram all of the stations when I put the fuse back in. where is the relay or switch that controls the power to the clock when the key is off
Old Jul 25, 2008 | 08:57 AM
  #36
rwrows's Avatar
what's the year make and model of your truck? mine was a 99 and it didn't lose the radio station settings when i pulled my fuse, however i did always have to reset the time. my problem ended up being the guage cluster. it didn't go into sleep mode when the truck was turned off. i threw another cluster in and everything was fine.
Old Jul 25, 2008 | 12:13 PM
  #37
FFJustin99Chevy's Avatar
FFJustin99Chevy is an unknown quantity at this point
ORIGINAL: Scooterewski
my under hood light stayed on and I pulled the bulb out...That was on my old blaze
Same here. It was drawing on my battery so I disconnected it. I just keep a flashlight in the door.
carbongixxer
Oct 9, 2013 01:13 PM
Barbara
Jan 22, 2012 09:53 AM
JShark
The Chop Shop
42
Mar 30, 2010 05:37 PM
djdrew010
Oct 29, 2008 08:20 PM
rlb
Nov 24, 2007 06:33 PM
