Battery or fuel injector?
Old Feb 15, 2020 | 03:05 PM
Small Arms Collector's Avatar
Small Arms Collector is on a distinguished road
Default Battery or fuel injector?
So my 1998 has an ongoing no start issue in cold weather, I have been able to get it to start up until a few days ago when the temperature dropped to 7, I tried repeatedly without luck, it cranks but will not start. Later when the temperature climbed to 20 I tried again, almost started, but no dice. After a few more attempts I noticed the cranking getting progressively slower, like it was a low battery.
I just tried again, it is now 27 degrees, still no start and crank remains slow, now it barely turns over at all and all the dash lights turn off while it is trying to crank. Battery indicator barely comes off the stop.
For context, normally when I move the key to the on position the voltmeter barely reads 10 volts (or a bit under), ditto for cranking, but after starting it shoots to 14 and stays there.
Restarting is seldom an issue, as long as it has only been a few hours or less since it last ran, otherwise it gets harder the longer it sits.
Do I have a battery issue, a fuel pressure (injector?) issue, or both?
Battery was new as of last summer, but was the cheapest advance auto had in stock.
I’m thinking that my battery was questionable and my repeated failed start attempts killed it, what do you think?
Old Feb 15, 2020 | 07:36 PM
With cold weather and slow cranking, I good place to start is suspecting the battery. Besides, it is super easy to have it tested. Sometimes you get a dud and only when it is cold does it poor quality become apparent.
You might take it to a place other than Advance Auto to check to get a second opinion before taking it to Advance Auto.
Old Feb 16, 2020 | 04:12 PM
Got it started today, had to jump it.
Before I jumped it, this is what the battery gauge looked like:
Battery almost drained.
After restarting it the gauge moved to just under 14 volts. I drove it back to Advance Auto (This is Sunday) and they tested the battery, said it was reading normal and putting out 12.48 volts, suggested I might have a corroded connection somewhere.
Do you think they are right? Where should I look? Could a corroded connection have been the source of my cold start issues all along?
Old Feb 16, 2020 | 04:50 PM
GeorgeLG's Avatar
A proper battery test uses a carbon pile or wire coil resistor load to check the voltage drop under a heavy load, after the battery is fully charged.
You can get close with:
1) Fully charge the battery. Turn on the headlights for 30 seconds to knock off the surface charge. Measure the battery voltage at the batt terminals and confirm.
2) While cranking, measure the voltage at the battery terminals and then again at the large battery cable on the starter and a ground nearby.
This will tell you if the battery is getting fully charged, what the voltage drop is under a massive load and what the voltage drop is in the connection and cabling.
George
Old Feb 16, 2020 | 05:16 PM
After restarting it the gauge moved to just under 14 volts. I drove it back to Advance Auto (This is Subday) and they tested the battery, said it was reading normal and putting out 12.48 volts, suggested I might have a corroded connection somewhere.
What could be happening is that there is a bad ground that is limiting the current that allows it to be charged and, if charged, limits the current that can flow to the starter.
In the process of doing a jump start, the regular grounds now have another ground path in parallel to them. So that if they are bad, then current can flow thought he wires.
Old Feb 17, 2020 | 10:36 AM
LesMyer's Avatar
George
This above!!!!
On the battery. Here's some more info. Tests they do at the parts stores are a joke. https://www.liveabout.com/vehicle-ba...esting-4083840 Your battery was either discharged or it is bad.
That said, it's my experience that these Blazers start SOOOOO easily in the cold weather it amazes me. Barely turn my engine over at 0° and it's running. I would stick a fuel pressure gauge on it. You may have more than one problem.
Old Feb 17, 2020 | 12:14 PM
GeorgeLG's Avatar
If it is determined that you have a battery/voltage problem then you need to determine the cause:
Bad battery
Bad alternator/regulator/diodes
Bad cables
Bad connections
George
Randy Josphe Wells
Jun 30, 2020 01:06 PM
chevy2
Dec 30, 2017 01:12 PM
spiderx
Nov 23, 2012 12:03 PM
19echo95
Oct 11, 2011 09:15 PM
midnightmekanik
22
Jul 11, 2009 07:30 PM
