Battery keeps going dead
Old Apr 2, 2019 | 06:28 AM
Mycarsucks's Avatar
Mycarsucks is on a distinguished road
Default Battery keeps going dead
My electric door locks keep looking and unlocking the doors causing battery issues . I think my remote for the factory alarm is the cause of this is this possible?
Old Apr 2, 2019 | 06:53 AM
cleburne red's Avatar
If you suspect the remote, pull the battery out of it for a day or two, see if the problem persists, maybe
Also, welcome to the forum!
Old Apr 2, 2019 | 07:15 AM
Mycarsucks's Avatar
Default Remote battery
So after finally getting my alarm remote open to remove battery I discovered that a part on the little circuit board is totally broke off. So I'm thinking this is the cause for my battery dying , now next question will a aftermarket remote from Auto zone be an ideal replacement if so is programming them a process better left to the pros, and if it's not a good replacement any recommendations on where to get a good one in or around PHOENIX, AZ . THANKS for the welcoming I think my 99 blazer and I are going to enjoy this forum. Thanks guys.
Old Apr 2, 2019 | 07:36 AM
Man, I know on my 95, there's like a plug up under the dash you jumper across to program remotes to the truck. I'm pretty sure it was changed by 99, but don't know more than that.
I've seen people talking about it on here about it before, you might need to do some digging
Old Apr 2, 2019 | 07:37 AM
TonyZR2's Avatar
TonyZR2 is an unknown quantity at this point
Pick up a brass battery disconnect wheel-****. Those green ones. Walmart has them. Install it on your negative terminal and it will at least keep your battery from going dead........when you decide to leave it "open". If you are using a side terminal setup, then I guess you'll need an adaptor (a screw in "top post").
Old Apr 2, 2019 | 08:10 AM
GeorgeLG's Avatar
You don’t list your year but I bought my remotes off eBay and programming was easy on my 2002.
George
Old Apr 2, 2019 | 10:33 AM
go chevy's Avatar
Welcome aboard! He has a 99 Blazer if I read it right...
Old Apr 2, 2019 | 10:49 AM
GeorgeLG's Avatar
Here is an example:
https://www.ebay.com/itm/New-Replace...rd!32907!US!-1
I don't endorse this choice and I don't remember who I got mine from off eBay. That said, this looks like a good source to consider. You need to double check the numbers off the back of your remotes.
Good luck,
George
Old Sep 4, 2020 | 02:36 PM
davefandonwon's Avatar
davefandonwon is on a distinguished road
Got a battery disconnect switch, put it on the negative terminal. Knife switch, need to open the hood to use it of course. Looking for a remote switch but with limited space on 04 Blazer, doesn't look like a remote will fit.
wolfmage
Dec 17, 2014 06:26 PM
99lsdriven
Feb 6, 2013 01:01 AM
chaoticdopey
Aug 7, 2011 03:01 AM
blazinloud
Dec 28, 2010 10:27 AM
viper4559
Dec 17, 2009 08:01 PM
