Belt slipping/Alternator??
Old Jun 3, 2008 | 11:38 PM
sh1520's Avatar
sh1520 is an unknown quantity at this point
Default Belt slipping/Alternator??
Hey all- Had a weird thing happen to me. Stopped at a gas station before work to get a drink. When I came back and tried to start the engine, all the lights dimmed and it wouldn't start. So, I popped the hood and checked the battery cables and they were tight. I got lights on and went back and tried to start it again. It started, but if I even let off the gas it would die. I finally got it to start and maintain idle and drove it to work, and all seemed good. Then I remembered this--it had rained earlier, and when it rains my serp belt must get wet somehow, and it squeals for awhile. I have no idea why it does this because it's real annoying. Anyway, the belt's only a year old, but it was sqealing when I was first driving it. So I figure it was slipping pretty bad and not turning the alternator for power. Am I correct? And if so or not what do I do about the belt slipping? And why does it always get wet? Any ideas would be appreciated.
Old Jun 4, 2008 | 07:42 PM
getonerd's Avatar
getonerd is an unknown quantity at this point
Default RE: Belt slipping/Alternator??
water pump might be bad try to shake the pump pully if it moves is bad
Old Jun 4, 2008 | 08:25 PM
Davis83's Avatar
Davis83 is an unknown quantity at this point
I had a similiar issue with the 1 month old belt slipping/chirping. After checking everything and not finding any problems with pulleys....etc. I switched to a Gatorback belt and have had no problems since that time.
Old Jun 5, 2008 | 03:26 AM
sh1520's Avatar
Good advicedoes anyone know how/why it happens ONLY when it's rained? Or wet from fog/mist? Driving me nuts........!!
Old Jun 5, 2008 | 06:55 AM
Water can act like a lubricant when it gets on the belt. There is just something about certain belts and the way the serpentine setup works on these trucks that lends itself to squeal in wet conditions.
I had the same problem and a Goodyear Gatorback belt solved the problem. The Gatorback is a good belt!
Old Jun 5, 2008 | 05:23 PM
sh1520's Avatar
Thanks Kyleis the Gatorback something I can get at parts store, or is it a special order?
Old Jun 5, 2008 | 07:00 PM
Just have to check and see if you favorite parts store carries Goodyear belts. Most do.
Old Jun 5, 2008 | 07:48 PM
riceh8r0512's Avatar
riceh8r0512 is an unknown quantity at this point
I always tell myself that I will only put good parts on my truck if I have to repalce them. WHen it came tiem for a new belt I went with a Gatorback (expensive little bugger though) but I have to say it is a very nice belt.
Old Jun 7, 2008 | 04:01 PM
Davis83's Avatar
Quality cost more - it is a better belt.
Old Jun 7, 2008 | 04:49 PM
westphal's Avatar
westphal is an unknown quantity at this point
When you drive in the rain water goes through your grill, through the radiator and hits the pullys and almost everything else. Im sure it aint the water pump otherwise you would be adding anti freeze daily pending how often you drive it.One option would be to checkyour tension pully. If its loosing its strenth yourgunnahearslipping espciallywhen thebelt it wet. If theres no prob with the tension pully consider purchasing a new belt, within a year they can go bad.
Andy
kmclaugh84
Feb 11, 2014 07:42 AM
lionel2
Sep 7, 2012 02:45 PM
Sams95
Nov 28, 2008 09:09 PM
2001blazer
Feb 22, 2006 11:49 PM
