Blazer bogs down while accelerating
Old 07-28-2009 | 10:06 PM
karenlc's Avatar
karenlc is on a distinguished road
Unhappy Blazer bogs down while accelerating
Hello, I have a 1998 Blazer which bogs down when I accelerate. The Blazer will pick up speed if I let up on the accelerator and gently press the gas pedal down and baby it. I am not able to pass a vehicle on the highway because of not being able to accelerate when I need the power. The Blazer starts and idles great. Does anyone have any suggestions as to what my problem might be?
Old 07-29-2009 | 03:23 PM
When was the last time a full tune up (plugs, wires, cap, & rotor) was done? How about a new air filter? Or a throttle body, EGR, and/or MAF sensor cleaning? A dirty MAF sensor can cause issues like this. As can a faulty MAP sensor or TPS sensor.
Old 07-29-2009 | 10:52 PM
karenlc's Avatar
Smile
Thanks for the information!
Old 08-03-2009 | 11:50 AM
fireman77's Avatar
fireman77 is on a distinguished road
Having the same problem? Were you able fix yours? How?
Old 08-03-2009 | 02:58 PM
ws6power1's Avatar
ws6power1 is on a distinguished road
I'd check the fuel pump also. You might not have enough fuel pressure when your at full throttle.
Old 08-08-2009 | 04:25 PM
karenlc's Avatar
It turned out to be that my MAP sensor was bad. I replaced it and now my Blazer run great!!!!!!!!!!
Thanks for all of the help!!!
Old 08-02-2010 | 12:42 AM
coryreidmiller's Avatar
coryreidmiller is on a distinguished road
Default Blazer bogs even after changing engine out.
Hello, I have the exact same problem only MAF did not fix it.
I had a running 1999 4x4 pickup that I swapped all the parts over (MAF, coil, wires, etc....) and the 4x4 still ran great and the Blazer still bogged.
Then I swapped the entire engine into the Blazer and it does the exact same thing. I have plenty of fuel pressure when it is boggin and I have changed the fuel filter.
What is left? THe ECM??? It is not throwing any codes???? Help?
Old 08-15-2010 | 06:58 PM
hivolts's Avatar
hivolts is on a distinguished road
Default 1998 Blazer Bogs Down
I have the same problem. Did you figure your's out? No codes or check engine light on mine either.
Old 09-19-2010 | 10:34 PM
TRblazer's Avatar
TRblazer is on a distinguished road
i am having the same exact problem. although now my truck will barely even start. the mech said it might be a engine computer problem. Is the MAP sensor the same thing as a tps sensor. i have a 95. just looking for answers
hjelder23
01-19-2022 07:58 PM
Rwiley27
04-20-2014 02:31 PM
bertrenolds
13
01-17-2011 12:11 PM
MikesBlzr
05-18-2010 07:14 PM
dpatrick
Engine & Internal
10-12-2004 04:07 AM
Quick Reply: Blazer bogs down while accelerating
