blazer losesing power
Old Mar 20, 2009 | 07:07 PM
watsonmt's Avatar
watsonmt is an unknown quantity at this point
Default blazer losesing power
my friends blazer (1997) loses power when you step on the gass when it should shift into the passing gear instead it just bogs right out and slows down it dosnt stutter or threaten to stall it just feels like your trying to go up a huge hill towing like 6 other cars lol.... any thoughts guys. if you excel slow it seems fine but once you step on it and the tach hits 3 grand is when it happens
Thanks guys
Old Mar 20, 2009 | 07:23 PM
bandidolenny's Avatar
Tape a fuel pressure gauge to the windshield and go drive it to check the fuel pressure. Could be a clogged filter or a failing pump. Bad cat converter. When was the last tune up? Is there a check engine light? Scan for codes.
Old Mar 20, 2009 | 07:30 PM
watsonmt's Avatar
no codes and no engine light sorry hasnt had much of a tune up for a while im going to dig into somethigns tomorow when he comes over looking for some ideas of what to check, dont have a fuel presure gauge unfortunatly...
Old Mar 21, 2009 | 06:51 PM
watsonmt's Avatar
well we just tryed to start it and it idles up and down now and bogs out as soon as you touch the gas and you can hear the fule pump so thats what its is thanks guys, but i just called a parst store and they want 550 bucks for one....
Old Mar 21, 2009 | 07:33 PM
Pull the pre-cat O2 sensor (the one directly ahead of the catalytic converter) and see if the symptoms persist. If things get better with the O2 sensor out, your catalytic converter is clogged.
Old Mar 22, 2009 | 03:49 PM
I would try to rent or buy a fuel pressure guage and check the pressure before changing out a perfectly good fuel pump.
zrider79
Oct 15, 2010 09:55 AM
flipzat
Dec 2, 2009 04:05 PM
1991whiteoutblazer
Jan 8, 2009 08:17 PM
nate2003456
Jan 18, 2007 01:10 AM
freeman
Aug 23, 2005 10:55 PM
