Blazer not taking gas
Old 03-30-2010, 09:14 PM
thir13en's Avatar
thir13en is on a distinguished road
Default Blazer not taking gas
I have a 97 balzer that runs fine for a few miles then just will not take gas. It will idle fine and you can spray carb cleaner in the intake tube and it will take fuel fine. You can also turn the ignition off and start it right back up and it will be fine for a couple more miles and then do it again. The cel is not on so I have no codes. Ive replaced the distributor cap, rotor button, plugs, wires, crank sensor, cam sensor, tps sensor, coil, module, maf sensor, fuel pressure regulator, and spider all from a donor vehicle that ran fine. Nothing seems to help. Any suggestions?
Old 03-30-2010, 10:21 PM
BlazerGuy2001's Avatar
have you tried replacing the fuel pump and fuel filter? the problem could be that the engine is not getting the fuel? just a suggestion i could be completely wrong lol
Old 03-31-2010, 08:33 AM
Is the CEL (check engine light) on?
upmaine
05-09-2012 07:28 PM
TheBlazin
07-23-2010 08:07 PM
eastsiderides
03-28-2009 03:20 AM
slickster01
07-22-2008 07:48 PM
SnowRemorse
01-04-2008 11:26 AM
Quick Reply: Blazer not taking gas
