Blazer Runs in Idle and Neutral Fine, Bogs Down in Drive Sometimes Stalls
Old 08-12-2014 | 06:49 PM
rexazz2's Avatar
Originally Posted by jb34r5e
EDIT: I put a decent amount of water through my fuel system a while back on accident (fuel can with rain water inside) and am thinking the fuel filter is contaminating my fuel with moisture and could be bogging the vehicle down. I will try this next and see what happens.
throw a can of Sea Foam fuel treatment in the gas tank with the new filter
Old 08-13-2014 | 08:16 AM
LannyL81's Avatar
Yep....water in the fuel system is going to cause a problem! Only way to get all the water out that I know of is to drain the tank and blow-out the fuel lines. Adding moisture absorber to the fuel will help a little, draining tank best option.
Old 08-13-2014 | 04:08 PM
jb34r5e's Avatar
jb34r5e is on a distinguished road
I replaced the fuel filter today but did not fix the problem. The fuel system seems to be working properly. I think it is an air issue or faulty wiring/plugs. Does anyone know of any commonly faulty hoses or sensors? I will be checking spark plugs, changing cap and rotor and will get back with the results. The RPM drop is preceded by the temp gauge dropping to 0.
Old 08-14-2014 | 01:59 PM
jb34r5e's Avatar
I am wondering what people think about this being a possible ECU problem? Since the car drives and runs normally until operating temperature is hit, could it be that the computer is faulty? I just brought my car to Firestone to get tested and they told me I could have a faulty coolant temperature sensor. Would this be worth replacing even though it does not affect the engine or should I try the ECU?
Old 08-14-2014 | 10:15 PM
jb34r5e's Avatar
Ok guys, just got back in from working on the Blazer all day. I checked for vacuum leaks, MAF sensor voltages, re-seated all connections (easily reachable) and cleaned them. After an extremely long day, I decided I was going to locate the coolant temperature sensor and check it out. After finally locating it, I found that the input harness on the sensor itself had broken off onto the female wire connector. I was stoked to finally see something wrong with a system that is closely related to the problems and symptoms I've been having. I just removed the old temp sensor and am looking forward to replacing it in the morning. Because the 2 prong connector was semi-exposed ( I could see fresh metal of the prongs, looking down) I believe this is causing my intermittent temp gauge drop offs and coincidental RPM drops due to the mixture/ECM information relay being incorrect or inconsistent due to connection problems!
Here is what the plug looked like when I pulled it off of the temp sensor. Notice that the housing of the sensor is on the plug.
Here, I took the broken housing off of the plug:
Lastly, the broken temp sensor with the housing piece the plug had on it. Name:  arxSuif.jpg
Attached Thumbnails Blazer Runs in Idle and Neutral Fine, Bogs Down in Drive Sometimes Stalls-nrzbalk.jpg   Blazer Runs in Idle and Neutral Fine, Bogs Down in Drive Sometimes Stalls-kuyrzjv.jpg
Old 08-15-2014 | 09:52 AM
LannyL81's Avatar
All Right!!...hope this cures the problem.
Old 08-15-2014 | 10:00 AM
jb34r5e's Avatar
Thanks man! Will give an update once I put it in after work!
Old 08-15-2014 | 08:21 PM
jb34r5e's Avatar
After replacing the coolant temp sensor and making a solid connection, the car has been running smoothly. This case is closed!
Old 08-16-2014 | 09:13 PM
LannyL81's Avatar
Another GOOD to read...."Problem solved.".....YES!
Old 08-17-2014 | 12:00 AM
jb34r5e's Avatar
Thanks Lanny, feeling good about the fix and hopefully people find this thread useful in the future when running into similar issues.
Juice01
02-02-2013 12:25 PM
benman
08-29-2012 12:45 PM
bam_9_9_9
21
04-10-2011 09:19 PM
jceney87
01-24-2011 07:57 PM
EricTrembath
01-19-2009 04:49 PM
Quick Reply: Blazer Runs in Idle and Neutral Fine, Bogs Down in Drive Sometimes Stalls
